<< Click to Display Table of Contents >> Common Properties |
This section contains information about the common properties of all Screen objects. Properties on this section do not apply to the ActiveX (MSForms), E3Chart, E3Browser, and E3Alarm objects. These objects are described later, on their specific chapters.
NOTES |
•E3 uses the Himetric system to define coordinates and widths. In this system, each logical unit is equivalent to a thousandth of a centimeter, that is, 1,000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing E3 properties, when applicable. •The next properties are common to all previously cited objects, including Groups of objects and Dynamic Move and Rotate. |
The available properties on this section are the following:
•Tip
•X
•Y
