<< Click to Display Table of Contents >> InitialScreen |
Indicates an initial Screen or Frame to display when E3 Viewer is opened. By using the WindowStyle property, users can determine whether this window must start maximized, windowed, or minimized. Default value of this property is "InitialScreen". To use this property in scripts, please check the Splitter's SplitLink property for more information about the format to specify a Screen in this property.
