<< Click to Display Table of Contents >> GetValue |
GetValue(TagName)
This method searches for an object's value specified in the TagName parameter. If TagName points to a property, this method returns that property's value. However, if TagName parameter specifies an object, this method returns the value of that object's Value property. The next code contains a usage example of this method.
Sub Button1_Click()
' When clicking this button
' retrieves a Tag value
' executed on a Data Server
X = Application.GetValue("DataServer1.InternalTag1")
