ChangeUserPassword
ChangeUserPassword
ChangeUserPassword(Username, PasswordOld, PasswordNew, [OpStatus])
This method allows changing a user's password without displaying any message. The Username parameter is the user's name, the PasswordOld parameter is this user's current password, and the PasswordNew parameter is the new password. The optional return parameter OpStatus is a map of bits indicating the status of this operation. This method returns a Boolean indicating whether this operation failed or not. Please check table Possible return values for the OpStatus parameter in the LoginUser method for more information about possible values in case of failure.
NOTE
Whenever users change their password, a logout is performed from all sessions where these users were logged in, except from the session where this password change was performed.
