<< Click to Display Table of Contents >> WriteFeedbackMode |
This property allows controlling a confirmation or feedback of Tag writings. The configuration options for this property are described on the next table.
Available options for the WriteFeedbackMode property
Option |
Description |
0 - wfWaitNextRead |
After writing, waits normally for the next reading |
1 - wfImmediateReadAfterWrite |
Forces an asynchronous reading of a device right after each writing (default) |
2 - wfTrustWriteSuccess |
The written value is immediately assumed by the Tag, if the writing was successful |
NOTES |
•This property cannot be changed with the object still active. •In option 2 - wfTrustWriteSuccess, for asynchronous writings, the value is assumed in the Tag after scheduling a writing, if the operation is successful. However, if that writing fails later, the Tag's value may be wrong. For synchronous writings, the value is assumed right after the writing finishes, if successful. |
