<< Click to Display Table of Contents >> ServerStatus |
Determines the status of an OPC Server connection. This is a read-only property. The available options are described on the next table.
Available options for ServerStatus
Option |
Description |
-1 - ServerStatus_Unknown |
The OPC Driver is connected to an OPC server but either status is not informed or OPC client's ReconnectPeriod property is set to zero (default) |
0 - ServerStatus_NotConnected |
The OPC Driver is not connected to an OPC Server. This happens when, for example, an OPC Driver is not active, or a connection was not established yet for any reason |
The following values are only informed when the ReconnectPeriod property is different from 0 (zero). This time period specifying a status is retrieved from the server. In case this status is not correctly informed, this property can maintain its value in -1 (minus one), or the disconnection can be detected in this case, which brings the ServerSatus property to 0 (zero). Values are based on the five default status types defined for OPC servers.
Available options for ReconnectPeriod different from zero
Option |
Description |
1 - ServerStatus_Running |
Server is executing normally |
2 - ServerStatus_Failed |
Server is not executing. An unspecified error occurred on the server |
3 - ServerStatus_NoConfig |
Server is executing, but without information about its configuration |
4 - ServerStatus_Suspended |
Server was temporarily suspended |
5 - ServerStatus_Test |
Server is in test mode |
Example:
Sub CommandButton1_Click()
Dim status
status = Application.GetObject("OPCDriver1").ServerStatus
MsgBox "Driver status is " & status
Select Case status
Case -1
MsgBox "OPC Driver is connected to the OPC Server_
but its status was not informed."
Case 0
MsgBox "OPC Driver is not connected to an OPC Server."
Case 1
MsgBox "The OPC Server is running normally."
Case 2
MsgBox "The OPC Server is not running."
Case 3
MsgBox "The OPC Server is running without information_
on its configuration."
Case 4
MsgBox "The OPC Server has been temporarily suspended."
Case 5
MsgBox "The OPC Server is running in Test Mode."
End Select
NOTE |
To obtain a behavior equivalent to a Boolean property, it is recommended to use ServerStatus different from 0 (zero). This basically differentiates only between having or not having a connection, without considering more specific server statuses. In addition, this expression does not depend on using the ReconnectPeriod property different from 0 (zero). |
