<< Click to Display Table of Contents >> Run Application |
Executes a specific application.
Settings for the Run Application Pick
Available options for Run Application Pick
Option |
Description |
Command |
By clicking |
Parameters |
Allows specifying arguments for application's call |
Start in folder |
Determines the working directory of the application to execute |
Window type |
Determines the type of the execution window for the application. Possible values are Normal, Minimized, or Maximized |
