<< Click to Display Table of Contents >> Open Modal Screen |
Opens a Modal Screen, that is, a Screen that does not allow user interaction with other Screens while it is active.
Settings for the Open Modal Screen Pick
Available options for Open Modal Screen Pick
Option |
Description |
Open Screen |
Selects the Screen to open |
Title |
Defines the window title. This text is concatenated to the Screen's name |
Initial zoom |
Defines Screen's zoom, when displayed |
Parameter |
Indicates a parameter to pass when calling the Screen |
Enable scrollbar |
Allows using scroll bars on the Screen |
Specify screen position |
Determines the frame's position, in pixels, on the Screen, starting at Screen's upper left side |
Specify screen size |
Determines Screen's width and height, in pixels or Himetric |
Window Style |
Allows configuring the style of the window to display, by defining title and the availability of borders and the close, maximize and minimize buttons, among other settings (check the Window Style Dialog Box topic) |
