<< Click to Display Table of Contents >> MatchFound |
Indicates whether a user-typed text matches any entry on a list. If this property is set to True, the content of the Value property matches one of the records on a list. Otherwise, the content of the Value property does not match any of the records on a list (default). This is a read-only property, and does not apply when the MatchEntry property is defined as 2 (two). Default value of this property is False.
