PrinterName
PrinterName
Text Name of the printer used by the Line Printer object. Default value of this property is an empty String, that is, the Line Printer object uses Windows default printer.
NOTES
If this property is configured with an empty String and the UseDefaultPrinter property is configured as False, printing is not possible and the PrinterStatus property returns the value 0 (zero, psUnknown).
Windows default printer for the currently logged-in user may be different from the default printer used by E3 Server. This printer is identified by the icon Impressora padrão do E3 Server on E3 Admin - Printer window. To do so, right-click E3 Admin's icon on Windows Notification Area and select the Printer option.
