<< Click to Display Table of Contents >> LineWeight |
This property specifies a width for this object's line. Configuring this width to 1 (one), this object's line expands in up to 15 points. Configuring this width to 2 (two), this object's line expands in up to 30 points, and so on. The higher the number configured in this property, the larger the object's width. Default value of this property is 1 (one).
