<< Click to Display Table of Contents >> Deactivate |
Deactivate()
This method deactivates a previously created object, or an object previously activated using the Activate method. Users can deactivate an object when they must perform a previous configuration, such as initializing a property, or when they want to perform tests in which an object cannot be present and active. Example:
Sub CommandButton1_Click()
Dim obj, newObj
Set obj = Application.GetObject("Data")
Set newObj = obj.AddObject("DemoTag", True)
' Deactivate the object
newObj.Deactivate()
NOTE |
Deactivating an object using this method configures the IsObjectActive property of this object to False. |
