<< Click to Display Table of Contents >> Alarm |
Indicates that there are active Alarms in an object. If this option is set to True, there is at least one active Alarm inside an object, and the ActiveAlarms property performs a server reading, indicating the number of active Alarms. Otherwise, the ActiveNACKAlarms property performs a reading of non-acknowledged Alarms. This is a read-only property.
