<< Click to Display Table of Contents >> VerticalAlignment |
Defines a vertical alignment for an E2Display's text. Available values for this property are the following:
•0 - VerticalAlignmentTop: Aligns vertically with object's upper side
•1 - VerticalAlignmentMiddle: Aligns vertically with object's center (default)
•2 - VerticalAlignmentBottom: Aligns vertically with object's bottom side
