<< Click to Display Table of Contents >> ShadowY |
Defines an upper horizontal coordinate for this object's shadow, in Himetric units. This shadow is always relative to this object's Y property. Positive values indicate that this shadow is under the object, and negative values that it is above the object. Default value of this property is 200.
NOTE |
This property is only effective when a Picture object is working with Metafiles (WMF or EMF). |
