<< Click to Display Table of Contents >> Properties |
This section contains information about the properties of a Query (E3Query) object.
NOTE |
It is not advisable directly accessing these properties via scripts. Users must access the Query object, passing parameters through the SetVariableValue method and then modifying filters or fields through the collection returned by the GetE3QueryFields method. |
The available properties on this section are the following:
•SQL
