<< Click to Display Table of Contents >> OnRead |
OnRead()
Occurs when the value of an OPC UA Block Element is received by an OPC UA server. Use this event to perform an operation right after changing any data in an OPC UA Block Element, in the Bit00 to Bit31, Quality, RawValue, or Value properties.
