<< Click to Display Table of Contents >> AfterStart |
AfterStart()
Occurs after the I/O Driver started to communicate. It is common to create a script for this event using the Write method to perform device configurations. Example:
Sub Driver1_AfterStart()
' After started, communication writes values
' to the equipment or device
Write 0, 2, 55, 2, 33.4
Write 0, 3, 55, 20, "Metal"
