<< Click to Display Table of Contents >> CustomConfigText |
Indicates a text that appears on the contextual menu for the configuration option of an ElipseX instance. This option only appears if there is a script associated to the CustomConfig event of the ElipseX definition. If this property's value is empty, the text "Configure" is then displayed on the contextual menu option. The default value of this property is an empty String.
