<< Click to Display Table of Contents >> EnableSortMarker |
Enables or disables an indication of column sorting on an E3Alarm. Only the first column used on sorting displays this indication. For applications created with version 4.8 or later, the default value of this property is True. For applications created in earlier versions and then updated to version 4.8 or later, the default value of this property is False.
Indication of sorting by the Message column in descending order
