Screens |
1.Select the "Login" Text on InitialScreen and click the Scripts tab on the lower side of the Screen.
2.On Click event, create a new Open screen-type Pick.
Open screen Pick
3.In the Open Screen option, select the SynopticScreen.
Open Screen option
4.On the "Quit" Text, create a new script on Click event, of type Script.
5.Using AppBrowser
, select Viewer's Exit method, Application.Exit.
Script on Click event
6.On Viewer's Properties window, select the InitialScreen on Initial Screen or Frame option.
