Screen and Screen Objects |
Screens are windows for monitoring processes, where users insert objects that are part of the interface of operators with a system. Each application can have an unlimited number of Screens.
Screen Objects are graphical elements that can be inserted on Screens to create a visual interface with a process. These objects can be created using the toolbar of a Screen or using the Objects menu.
Once selected an object to create, keep the left mouse button pressed on a Screen area while moving the mouse pointer (a dotted rectangle shows this object's size and shape). When releasing the left mouse button, the object is then positioned inside the specified area.
