Historic |
A Query object is also used to show historical values on an E3Chart. On the Queries tab users can add, delete, or configure Queries. To create a Historic
Pen, a Query must have been previously created. To do so, go to Pen properties' Data tab, select the Historic item on the Pen Type option, and then define a Query. After that, define Query fields on the Vertical axis field and Horizontal axis field options.
