Elipse Modbus Simulator |
Elipse Modbus Simulator is a generator of random values for applications compatible with Modbus RTU and Modbus TCP protocols. In addition, it also allows receiving writing messages performed by these applications. This program can be downloaded at Elipse Software's website.
When Simulator starts, its working area opens, as shown on the next figure.
Elipse Modbus Simulator's main window
The available options on this main window are described on the next table.
Available options on Elipse Modbus Simulator's main window
Option |
Description |
PLCs Quantity |
Number of PLCs to simulate. NOTE: In Demo version, this field is limited to 10 PLCs |
Initial Port |
Base port used for communication |
Random Values |
Enables or disables generation of random values |
Interval (ms) |
Variation range of values, in milliseconds |
Connection |
Type of connection to simulate (currently, the only available option is TCP/IP) |
Protocol |
Protocol to simulate (Modbus RTU or Modbus TCP) |
COILS |
Number of Coils to simulate per PLC (maximum limit is 255) |
REGISTERS |
Number of Registers to simulate per PLC (maximum limit is 255) |
After selecting the amount of PLCs and an initial port, start simulation by clicking Start.
