<< Click to Display Table of Contents >> Alarm Configuration |
An Alarm Configuration object is where Alarm Sources are created. To insert this object in a project, right-click the Server Objects - Alarms in Organizer, select the Insert - Alarm Configuration option, and then a project's name.
