<< Click to Display Table of Contents >> Configuration |
When a Storage is created on an application, it displays a list of definitions for recording fields, according to the next fields.
Storage fields
For later data querying, every search is performed by Tag path or property being stored (the Source column). The Name column is only used if the Source column contains an expression. Therefore, if expressions are not used in the Source column, there is no need to worry about the Name column.
