<< Click to Display Table of Contents >> Server Objects |
To access an object executing in a Server from a Screen Object or an ElipseX, users must use the Application.GetObject method. Example:
Server objects
•Application.GetObject("Data.InternalTag1"): Internal Tag on the Data Server
•Application.GetObject("Database"): Database
