<< Click to Display Table of Contents >> IOKit |
IOKit is a shared component used by Elipse Software's I/O Drivers, implementing default access to physical layer and providing interfaces to Serial, Modem, Ethernet, and RAS.
Currently IOKit only allows a single connection for each Driver. This means that, if users need access to two serial ports, two Drivers must be added to the application and each one of them configured for each serial port.
