E3 Server Configuration |
An E3 Server performs a certain number of protection device's reading tries. If this reading is not successful, E3 is then started in Demo mode.
In case of bi-processed computers, users can configure an E3 Server to use only the first or all available CPUs on the computer.
Users can force E3 Server to quickly detect remote E3 Viewer disconnections, interrupting data accumulation to send to an E3 Viewer.
During a connection from a server's license to an E3 Viewer, a keep-alive (or heart beat) is applied by default. If an E3 Viewer remains some time without responding, its connection is automatically closed.
Users can configure a port number used by the REC protocol. Values between 1024 and 65535 can be used. Values smaller or equal to 1024 are reserved. Null or invalid values enable using the port 6515.
Users can specify the maximum time, in milliseconds, to quit E3Run.
