Preparation for Certification |
Recommended readings:
•Basic VBScript for Elipse E3: Introduction
•Using Libraries in Elipse E3: Introduction
•Using Viewer in Elipse E3: Introduction
•Using Databases in E3: Introduction
These are some exercises to study for certification test:
1.By using E3's graphical resources (circle, rectangle, line, etc.), create a speedometer.
2.Create an application with a chart. When opening a Screen, that chart must display the last 20 minutes.
3.Export a graphical report to a PDF format.
4.Insert a Check Box on a Screen that lists all Demo Tags from Data folder. When selecting a Tag on that list, a Display must be created at run time and linked to the selected Tag.
