Studio |
•Fixed the update of inactive Screens in E3 Studio when the grid is activated or deactivated.
•Combo boxes on the Format toolbar are now only enabled when users select an object with a Font property. This bug occurred since v2.0.20.
•Fixed the behavior of expanding all items in Views that display XObject instances. This bug occurred since v1.18.30.
•Menu buttons in E3 Studio toolbars are now correctly disabled. This bug occurred since v1.0.16.
•Keyboard focus now remains on the Properties List when E3 Studio is minimized and maximized. This bug occurred since v5.0.231.
•E3 Studio now correctly closes when there are floating and sliding windows. This bug occurred since v5.0.244.
•Fixed duplicated shortcut keys for the Apply option on the data configuration tab of Pens of an E3Chart.
•The contextual menu of Screens now displays again the Verify option. This bug occurred since v5.0.374.
•Now docked windows correctly pass along focus when changed to sliding mode. This bug occurred since v2.0.22.
•Remapped the shortcut keys of controls of General and Visual Reference tabs of E3Chart Axes.
•The combo box of Scripts View can now be used normally on a floating window. This bug occurred since v5.0.229.
•Now users can use the menu in E3 Studio window with a floating Organizer. This bug occurred since v5.0.178.
•Fixed the behavior of No for All and Yes for All options when closing E3 Studio. This bug occurred since v4.7.38.
•The Explode Symbol (convert into a group) option was optimized and it is faster in complex objects.
•Fixed a GPF (General Protection Failure) that occurred when trying to convert to symbol a metafile containing EMR_POLYBEZIERTO16-type records.
•Sub-items of contextual menus now do not display nonsense messages anymore in E3 Studio status bar. This bug occurred since v4.8.243.
•Fixed a GPF (General Protection Failure) when closing the window to import OPC Tags. This bug occurred since v1.0.0.
•Removed an unnecessary message about saving project and library files and fixed the Save option in E3 Studio toolbar to fully save folders, projects, and libraries. This bug occurred since v5.0.363.
•Fixed a GPF (General Protection Failure) in E3 Studio when opening a Domain on the list of Recent Domains. This bug occurred since v3.0.223.
•Restored the drawing of Properties List's borders of E3 Studio on Windows 10.
•Now E3 Studio is visible on Windows ALT + TAB window even when there is a sub-window of the Properties Window open.
