Database
Database
Now users can edit the SQL Server connection String, allowing, for example, connect to a SQL Server with Mirroring enabled.
Improved server logs to indicate when an object such as the Database Server, Storage, or Alarm Server is searched by E3 Viewer but not found, or it is not the expected type.
When the load of Oracle client DLL (OCI.DLL) fails, the log registers the environment variable Path, to improve diagnosis.
