<< Click to Display Table of Contents >> OPC Driver |
•Corrected the behavior of the OnTagWrite event of an OPC Driver, which was not generated when performing asynchronous writings if the communication with the server used the OPC DA 1.0 standard, or if the asynchronous writings failed immediately. This bug occurred since v3.2.95.
