Retentive |
Indicates whether the current Property Definition's value at run time is persisted in the Domain file (True), while the Domain is loaded. A retentive Property Definition is represented by the icon
. Retentive Property Definitions have the following behavior:
•Propagate their value to the Standby server
•Keep their value if the application is updated at run time
•Keep their value if the application is stopped (as long as the Domain is not unloaded)
NOTES |
•This property is only available for Property Definitions whose data type is not an object (Variant, Double, Integer, etc.). •Using this property in True implies in raising E3Run's memory and CPU usage, therefore it must be used carefully. |
