ShowTrendAnalysis |
ShowTrendAnalysis([Title], [Left], [Top], [Configuration], [ConfigStatus], [ErrorDetails])
Shows a TrendAnalysis window. This method returns True if this window was correctly shown or False in case of error. This method's parameters are listed on the next table.
Parameters of the ShowTrendAnalysis method
Parameter |
Description |
Title |
Determines a window title. Corresponds to TrendAnalysis object's Title property. If omitted or informed an empty String, this window's title is configured as "TrendAnalysis" |
Left |
Window's horizontal coordinate, in pixels. Please check TrendAnalysis object's SetWindowPlacement method for more information about the behavior of this parameter, if omitted |
Top |
Window's vertical coordinate, in pixels. Please check TrendAnalysis object's SetWindowPlacement method for more information about the behavior of this parameter, if omitted |
Configuration |
Informs the content of a configuration saved by TrendAnalysis object's Save method. If omitted or informed an empty String, no previously saved configuration is loaded |
ConfigStatus |
An optional return parameter that informs the result of loading a TrendAnalysis window. If this method returns True, this parameter contains the value 0 (zero), that is, the configuration was successfully loaded. If this method returns False, this parameter can contain values 1: Configuration did not load correctly, 2: Configuration content is invalid, or 3: Configuration requires a newer version |
ErrorDetails |
An optional return parameter containing a String with details about the error when loading TrendAnalysis window |
Usage example:
Sub Button1_Click()
Dim showResult, errorMsg, errorDetails
showResult = Application.ShowTrendAnalysis("TrendAnalysis", 100, 100, "", ConfigStatus, errorDetails)
If showResult = False Then
If ConfigStatus <> 0 Then
Select Case ConfigStatus
Case 1
errorMsg = "Error (1): Configuration did not load correctly."
Case 2
errorMsg = "Error (2): Configuration content is invalid."
Case 3
errorMsg = "Error (3): Configuration requires a newer version."
End Select
errorMsg = errorMsg & vbCrLf & "Details: " & errorDetails
MsgBox errorMsg
End If
End If
NOTE |
TrendAnalysis properties can be configured in the object returned by Viewer's GetTrendAnalysis method. |
