ScreenAlignment |
Controls the alignment, given by E3 Viewer, of all Screens that do not specify a value different from default. Possible values for this property are the following:
The next figure shows an E3 Viewer's contextual menu at run time, with the respective configuration options of this property.
Options for E3 Viewer's ScreenAlignment property at run time
