IsAppRunning |
IsAppRunning(ProcessId)
Indicates if an application started by the ExecuteExternalApp method is currently executing. Returns True if an application identified on the operating system by ProcessId is executing. Otherwise returns False. Example:
Sub CommandButton1_Click()
Application.ExecuteExternalApp _
"www.elipse.com.br", "", "", 1, processID
While Application.IsAppRunning(processID)
' Waits for this application to end
Wend
MsgBox "This application ended!"
NOTE |
The ProcessId parameter is the same value appearing on Windows Task Manager, on PID column. |
