GetFormulaValueDataObj |
GetFormulaValueDataObj(FormulaName)
This method retrieves all settings from existing values of a certain Formula. Values are a data set saved in a Formula. This method contains the FormulaName parameter, which informs Formula's name.
Use this method to get a collection of values of a Formula. This method returns True if this operation is successful or False otherwise. Example:
Sub Button1_Click()
Dim val
' When clicking the button, displays a message box
' with the number of Sets
' and the name of the First Set.
Set obj = Application.GetFormulaValueDataObj("Formula1")
MsgBox CStr(Obj.Count)
MsgBox CStr(obj.Name(1))
