BlinkTime |
Defines a time, in milliseconds, between each status change when an object must blink, that is, each time an object has a Link and the Blink option is selected. Default value of this property is 200 ms.
NOTE |
The minimum time to refresh a Screen is 55 ms. Therefore, if this property is set with a time less than that, this configuration has no effect at all. |
