EULow |
Defines the minimum value to set to the Value property, adjusting the scale to the value on the device before this attribution. Likewise, at the moment of the writing the inverse operation is executed before sending a value to the Driver. This conversion only occurs when the EnableScaling property is set to True. Default value of this property is 0 (zero).
