ServerState |
Returns the status of a connection or of an OPC UA server. This is a read-only property. Possible values for this property are the following:
•-1 - ussNotConnected: Server is not connected (default)
•0 - ussRunning: Server is executing normally
•1 - ussFailed: Server is not executing
•2 - ussNoConfig: Server is executing, but without information about its configuration
•3 - ussSuspended: Server was temporarily suspended
•4 - ussShutdown: Server was shut down
•5 - ussTest: Server is in test mode
•6 - ussCommunicationFault: There was a communication failure with the server
•7 - ussUnknown: Server status is unknown
