PicturePosition |
Indicates the position of the selected picture on Screen's PictureFile property. This property is only valid if the FillStyle property is set to 12 - Picture. Valid options for this property are described on the next table.
Available options for PicturePosition
Option |
Description |
0 - Center |
Picture with original size, centered on Screen (default) |
1 - Tile |
Picture with original size, repeated as many times as needed to fill a Screen |
2 - Stretch |
Picture resized to fill a Screen |
3 - TopLeft |
Picture with original size, on the left upper corner of a Screen |
4 - BottomLeft |
Picture with original size, on the left lower corner of a Screen |
5 - BottomRight |
Picture with original size, on the right lower corner of a Screen |
6 - TopRight |
Picture with original size, on the right upper corner of a Screen |
