Close |
Close(Code)
Use the Close method to close a Screen. This method generates the OnHide event before being performed. The Code parameter contains the value returned by the DoModal method, if that Screen is called by this method. Example:
Sub CloseButton_Click()
' When clicking CloseButton, closes this window
Screen.Close(0)
