Bit00 to Bit31 |
These properties represent all 32 bits of an OPC Block Element's Value property, where Bit00 is the least significant bit and Bit31 is the most significant bit. Modifying each one of these bits implies in changing the OPC Block Element's Value property and vice versa, but this only happens when the UseBitFields property is set to True. Default value of these properties is False.
