ServerMachine |
This property determines the address of the station where the OPC server is executing. For applications executing locally, this property may remain blank (default). Otherwise, users must specify a path, such as "\\ServerName". This property can only be modified when the OPC Driver is disconnected. Example:
Sub CommandButton1_Click()
Set Opc = Application.GetObject("OPCDriver1")
Opc.Deactivate
Opc.ServerId = "ElipseSCADA.OPCSvr.1"
Opc.ServerMachine = "\\server2"
Opc.Activate
