Alignment |
This property specifies an object's position, relative to its legend. Available options for this property are the following:
•0 - fmAlignmentLeft: Aligns the legend to object's left side
•1 - fmAligmentRight: aligns the legend to object's right side (default)
This property cannot be changed while this object is active.
