AddItem |
AddItem([pvargItem], [pvargIndex])
This method is used to add items to a List. The pvargItem parameter is a String containing a text to add to a List and, if omitted, adds an empty String. The pvargIndex parameter is the index of a text on a List and, if omitted, the value of the pvargItem parameter is added as the last item on the List. Example:
Sub CommandButton1_Click()
EntryCount = EntryCount + 1
ListBox1.AddItem(EntryCount & " - Selection")
