SpecialEffect |
This property specifies object's appearance. Available options for this property are described on the next table.
Available options for the SpecialEffect property
Option |
Description |
0 - fmSpecialEffectFlat |
Object appears flat and has a raised border, a color change, or both |
1 - fmSpecialEffectRaised |
Object is raised on its upper left side and a shadow on its lower right side, as a relief |
2 - fmSpecialEffectSunken |
Object has a shadow on its upper left side and raised on its lower right side. This object and its border appear sunken on a Screen (default) |
3 - fmSpecialEffectEtched |
Border looks etched around object edges |
6 - fmSpecialEffectBump |
Object has a ledge on its lower right side and looks flat on its upper left side |
