ListIndex |
Identifies the item currently selected on a list, which is called an index. The values of this property range from -1 (minus one) to the total amount of rows on a list minus one (that is, ListCount - 1). When no row is selected, this property returns -1 (minus one). When users select a row on a Combo, the system defines the value of this property. The value of this property on the first row of a list is 0 (zero), the value of the second row is 1 (one), and so on. This property cannot be changed while this object is active.
