SpecialEffect |
This property specifies an object's appearance. Available options for this property are described on the next table.
Available options for the SpecialEffect property
Option |
Description |
0 - fmButtonEffectFlat |
Object appears flat and has a raised border, a color change, or both |
2 - fmButtonEffectSunken |
Object has a shadow on its upper left side and is raised on its lower right side, as if it is sunken on a Screen (default) |
